1 - 13 of 13 Posts
Asshole
Alright so the tps on the z6 tb I have is smashed. I picked up a tb from an F22 with a perfect looking tps. However, the F22 uses a firewall mounted map sensor. My 94 hatch does not. I really dont want to remove the tps from the F22 tb and put it on the z6.
Suggestions? Are the 94-97 F22 tb mounted map sensors? Only reason I ask is because F22 are overly abundant in the local yards here where as any D and B series are not.
why not just switch over to a firewall mounted map? its easy and there are tons of hondas with that design also.
Asshole
You totally ninja edited that because thats not even close to what it said before!
Explain a little more please? If I dont find a CD6 tb Ill probably have to do this.
he didn't ninja edit it.......
just run a vacuum line, not very hard.
Lifetime Awesome Member
'89 CRX HF
Plug your existing map sensor plug into a firewall map(obd0 usually), then run a vac line from the IM to the nipple on the sensor...not hard at all.
Jeep wrangler DD
Or plug your regular map into the harness, run a vacuum line to it and you're done. Either make a mounting bracket, or ghetto zip tie it to something
1995 Civic Si/dx
I thought the F series had a slightly different bolt pattern.
they might im not sure but even so, I plan on making an adapter piece kinda like a spacer between the tb and intake manifold rather that port matching my original IM. The adapter would be matched to both sides so bolt patern wouldn't matter
1 - 13 of 13 Posts
