1 - 20 of 30 Posts
formerly Kit88
1st 2nd 3rd
60 ft ------- 2.153 ----- 2.338 ----- 2.008
1/8 mile ---- 9.411 ----- 9.386 ----- 9.212
1/8 mph ---- 75.500 ----- 78.549 ----- 74.860
1/4 mile ---- 14.556 ---- 14.344 ----- 14.270
1/4 mph ---- 97.265 ----- 101.078 ----- 94.245
Any body can help me to know why this differences??
2nd run, max speed but less 60ft.
3d run best time but less speed.... on this run I miss third.
I don´t understand.
formerly Kit88
first and 2nd about 4500-5000 and third at 5500 with launch control.
And boost at 1 bar
formerly Kit88
Your launchs changed so your results changed.
I know, but why on my best time the speed was lower than the others???
formerly Kit88
You missed thrid so you stopped gaining speed for a moment.
Do you think that I should get into high 13´s on third run???
formerly Kit88
It would have been close. Were you shifting at the same rpm's every run?
I´m not shure, I new running at the track, I´ll try to watch on it next sunday.
I need more practice ...
keep working them down man, your doing a good job. Dont change a thing in your setup until you can run solid numbers time after time!!!
formerly Kit88
Thanks bro, I´ll do
with a better launch you can run 13's @ around 99-100mph.. Id guess a 13.9-13.8 @ 100mph with a 2.0 0-60ft
formerly Kit88
Discussion Starter #14 (Edited)
COOL !!!!
I´ll install my lsd tranny this saturday I just receive it from Bone.
I´ll go for 13´s on sunday, wish me look guys.
remember that usually, id say 95% of the time..the rule of thumb is this..
The higher your 0-60ft number the higher the trap speed(due to more tire spin)
The lower the 0-60ft time the lower the trap speed(Cause there is less tire spin)
Missing a gear can take +/- .3 - .4 of your time(sometimes more depending on your reaction)
Run #3 looked like your 13 sec pass there, until you missed that gear.
formerly Kit88
Discussion Starter #16
YES !!!
Agreed on all points! They say a .1 improvement in the 60ft will net you .15 in the 1/4 mile, but the better the 60ft, the lower the trap speed as a rule (all other things remaining constant of course).
formerly Kit88
Discussion Starter #18
Now I got it clear, thanks guys.
I have a question :
Some guys over here told me that is better to not release the gas pedal between shifts, it is safe for my engine and tranny???
If it is safe, it will help me to improve my 1/4 mile time???
very true!!!!! tires make a hell of difference.
1 - 20 of 30 Posts
