1 - 4 of 4 Posts
G
heres the problem when coming home
and i get off on a off ramp i put it in Neutral and sometimes it sticks at 2,000rpm,
i notice when i lift up on the gas pedal the idle comes down, normal driving around town i notice its about 1350 then i lift up on the gas pedal it goes away
i basicly just need to adjust the thorttle right?
G
which nuts do i loosen theres one on the right one on the left, in this case i would need to make the cable less tight?
S
there should be two nuts about 6 inches off the throttle body on a bracker(youll see them) Losten the one on the left, the back the one out on the right till u get ur idel where u want it then tighten the other one up.
1 - 4 of 4 Posts
