1 - 10 of 10 Posts
Hi,
I was thinking about this turbo.
A Gt30-1
Specs:
Turbine Housing AR:A/R.63
Turbine Outlet: 5 BOLT STANDARD HOT SIDE
Comp. Housing AR: A/R.70
Compressor Inlet: 4" INLET DIAMETER
Compressor Outlet: 2.55" OUTLET
Turbine Wheel: *56-65.25 trim:71
Comp. Wheel: *61.4-82 trim:64
My HP-Goal is around 300 hp,
This is my speclist:
D16Z2 block
Z6 Head
75mm Vitara
Eagle H beam rods
ARP Headstuds
Y8 Intake manifold
60mm TB
525cc Precisions
2.5 inch piping
MSD Ignition
Is this turbo good for this setup?
I hope that ya all can help me.
Thanks,
Justin
セックス大好&#
'93 240sex
Seems to me that 525s would be too small for that big of a turbo, it may run way too lean. But i dont know jack shit about building turbo Ds, i could be completely wrong
GT30 for only 300hp? Don't do it.. Go with Gt2860 which will give you fast spool, wide powerband and meet you hp goal.
2015 SI 4dr
Get the FJT rods for Vitara setup so you can raise compression ratio up to around 8.5:1..regular eagles rods will cause you to have really low compression and the GT2860RS aka Disco potato will give you a nice power band..
Acura TL-P
GT 30-1??
I think people here are replying based on a Garrett 3071R or 3076R...which would not be the same as what you listed.
Yah thats the same as sc6256. Alot bigger then what people are thinking. Its overkill for sure. I like the T3T4 50 trims personally.
1 - 10 of 10 Posts
