81 - 100 of 119 Posts
95 CX Hatch
ENGINE: D16Z6
MILEAGE: 43k since built
CHASSIS MILEAGE : 351k
MILES SINCE BOOSTED: 43k
PSI: 15-22
TURBO: T3T04e 57 trim .63A/R
DRIVING STYLE: HARD and HEAVY!! (830lbs of stereo)
MANAGEMENT: P28 chipped with Crome Pro, street tune with dyno tweak at VTEC
HP: 341whp @ 22psi dynojet
ENGINE MODS: see sig
MAJOR PROBLEMS WITH CURRENT SETUP: driver is too pussy to turn it up more
newbie and noobie here..this is a very informative thread...
but i would like to ask you all how come everybody are using sdifferent turbo??are they similar??anybody on a bigger turbo??
i think most people just use the turbo they can get there hands on.... being an un turboed engine to begine with we have to piece together the setup ourselves. that would be why everyone ends up with different turbos and different turbo setups. and there are alot of d's using bigger turbos then most (most use t28 - t3)
ENGINE: D16Z6
MILEAGE: 86000
CHASSIS MILEAGE : 130000
MILES SINCE BOOSTED: 6000
PSI: 8
TURBO:ct26 of 6cyl supra
DRIVING STYLE:like i stoled it!!!!!!
MANAGEMENT: P28 chipped with Crome Pro, whitfield racing dyno tuned
HP: 189hp 157qt
ENGINE MODS: 65mm tb
MAJOR PROBLEMS WITH CURRENT SETUP: lag and oil seal but who cares!!
a noob that i am, i want to partake!
Engine: d15bvtec
Mileage before boost:0
Mileage after:27k(and thats with cross country trips!
PSI:15
Turbo: Super T3 45 Trim Stage III .48
Engine:bottom end had egle rods, wiseco pistons(CP 8.5:1), polished crank, and new oil pan
Head: mild port and polish, a turbo cam a friend gave to me, im really not sure where its from but damn it was good, brand new valvetrain components from skunk 2.
Management: chipped p28 with chrome, i had it street tunned by a friend first then went to the bronx for the dyno tunning
HP:370 198ft
Major Problems:hooking up, and trying not to bind my axles, i also had some lag in the beginning but that went away after the dyno tunning.
I drove that one into a grave and i dont mean the engine because my little brother has the motor now with the same turbo and he's pumping way more boost i think now he's at about 17 but with 750cc injectors and he's not driving it like i was!
new project is a b20 but i love my d's!
Administrator
93 cx hatch
ENGINE: zc vtec
MILEAGE: 65k on motor
MILES SINCE BOOSTED: 2800k
PSI:was 6.5 last 500 ish miles at 5 psi
TURBO: Turbonetics t3/t4 .60/.48
DRIVING STYLE: if im not in boost.. the car isnt running
MANAGEMENT: crome pro
HP: guessing 185 ish whp
ENGINE MODS: stock minus exospeed stage 3 cam and aem cam gear at 2 degrees retarded
MAJOR PROBLEMS WITH CURRENT SETUP: none as of right now... takes the beating daily and keeps on giving
ENGINE: d16a6 block, d16y7 head
MILEAGE: 4500-5000
MILES SINCE BOOSTED: 4500-5000
PSI:16-22psi depending on my mood
TURBO: not big enough
DRIVING STYLE: careful, but not like a grandma
MANAGEMENT: crome
HP: the goal was over 400 on high boost but it never made it to the dyno.
ENGINE MODS: eagle rods, SRP pistons, block guard, ARP head studs, ported head, cam, skunk2 intake mani, h22 throttle body, and some other shiet
MAJOR PROBLEMS WITH CURRENT SETUP: cracked sleeves in 7 places due to trying to make 400hp (at 10:1 compression on pump gas). It was a hot day when it went, IAT's must have just been high.
ENGINE: Sohc Vtec ZC (D16z6)
MILEAGE: unknown on motor
CHASSIS MILEAGE : 219k
MILES SINCE BOOSTED: 1000
PSI: 9-12
TURBO: GT2560R
DRIVING STYLE: Daily beaten
MANAGEMENT: Neptune
HP: [email protected]
ENGINE MODS: none
MAJOR PROBLEMS WITH CURRENT SETUP: No traction
ENGINE: D16Z6 block, Ported Z6 head, D17A1 Crank and Rods, D17A2 Pistons, .5mm over, 10.2:1cr
MILEAGE: 12,xxx
MILES SINCE BOOSTED: 12,xxx
PSI:10
TURBO: T3 .60/.63
DRIVING STYLE: Beaten Hard Daily
MANAGEMENT: Neptune RTP tuned by myself
HP: Roughly 250whp, Dyno soon
ENGINE MODS: Mirror polished rod beams, ARP rod bolts and head studs, Y8 aluminum oil pan.
TRANSMISSION MODS: Stock EX gearing with Quaife ATB and Gear-X 4.70 Final Dirve
MAJOR PROBLEMS WITH CURRENT SETUP: None
Ferio inspired
90' Civic sedan
Derek, you still rockin sohcturbo's old 57trim??:beer:
94 civic si
ENGINE: d16z6
MILAGE: 189k
MILES SINCE BOOSTED: 153
PSI:7
TURBO: garrett T3 .42/.48
DRIVING STYLE: minor aggresive ass hole
MANAGEMENT: vafc2
HP: unknown
ENGINE MODS: dsm 450's
MAJOR PROBLEMS WITH CURRENT SETUP: running rich/not tuned, clutch, open dump
things that have changed:
MILAGE: 189k ---> 193k
MILES SINCE BOOSTED: 4k
MAJOR PROBLEMS WITH CURRENT SETUP: running rich/not tuned, clutch, open dump---> clutch replaced with centerforce pp, lsd fly, stock clutch. still running rich/not tuned, piston rings gave way when doing a high speed run and now am boosting 11psi for some reason.
ENGINE: D16a6 Block with Z6 head
MILEAGE: unknown
CHASSIS MILEAGE : Approx 180,000
MILES SINCE BOOSTED: 6K
PSI: 13
TURBO: Turbonetics T3/T4
DRIVING STYLE: Road Rage!!!
MANAGEMENT: Hondata s200
HP: Somewhere between 250-300
ENGINE MODS: Pistons, and Rods
MAJOR PROBLEMS WITH CURRENT SETUP: Oil leakage on oil fitting:( Turbo leaking oil into charge piping:( SUCKY GAS MILEAGE! Its still fun as shit pulling EVERYONE(almost)
93 Civic EX
Motor: D16Z6
Mileage: 7k
Mileage since boost:0k
PSI: 10psi
Turbo: T3 Super 60 .42/.48
Driving Style:Raced over 50times at track/street and mountain driving
Management: Crome Pro
Hp: 228whp 200tq
Engine mods: ARP Headstuds, Cometic Headgasket, Wiseco Pistons, Eagle Rods, ACL Bearings, supertech valvetrain, carbing catch can
no problems. Only A/F street tuned. No major timing has been tuned yet.
Motor: D16Z6
Mileage/Chassis: 118K
Milegae since boost: 9K
PSI: 13
Turbo: T3/T4 50 trim (50 ar/ .48ar)
Driving style: Drive it like you stole it!
Engine Management: Crome
HP: 235whp 205tq
Engine mods: Bone stocker
Major problems: None
'95 Civic dx
Motor: D15z6 (D15z1 block/z6 head)
Mileage: 170k
Mileage with setup:5k
PSI: 16psi
Turbo: T3 .42/.48
Driving Style: Opposite of grandma
Management: Crome Pro; 390cc
Hp: Enough to get me [email protected] without slicks or lsd
Engine mods: Nothing besides the minime... it puts me around 7.8:1 C/R though...
Major problems: No traction; MAJOR head lift
yo whats up i just got a 91 hatchback and its stock but I want change the motor and turbo it with a T25 I picked from my boy. Can u help me out and give me some directions and how to achieve a D-motor boosting.
97 civic dx
Motor: D16Z6
Mileage: 180k
Mileage with setup:4k
PSI: 18psi
Turbo: Turbonetics T3/t4 50trim
Driving Style: boost head
Management: Crome Pro, dsm 450, msd 3bar, 255 pump
Hp: 271hp 220tq
Engine mods: eagle rods, vitara piston stock bore, acl race bearings, arp studs.
me too im so anxious. i need to do a compression test on my motor though.
