1 - 10 of 10 Posts
I've got a small hole in my OEM catalytic converter on my 98 Hatchback with a y8 header/cat. Its on the piping so it's patchable via some welding. But I'm looking at maybe replacing it altogether as I got the cat used from a guy on HT (couldn't go wrong for $30 with a working O2!).
Here's my setup:
ebay y8 Header
OEM cat (unknown mileage, though I've put about 25k on it in the last year)
Spec Tuning Cat-back
I live in Ohio, so no need for emissions testing. I'm not looking for ridiculous loud, which is part of my question; if I go the test pipe route (such as the ebay option) how much louder is the exhaust going to be? Seeing as I'm OBD2, and running a 2nd O2 in the Cat, will it throw a CEL if I plug the O2 into the testpipe?
In my old 96 H22 Accord, I had a DC header, MagnaFlow hi-flow cat, and Apexi WS2 and loved that tone. If I can find it, a WS2 will be going on this, but that's for another day.
What is everyone's thoughts on a testpipe such as the ebay one linked above vs. a high-flow vs. an OEM?
formerly allnaturalrex
1989 honda crx si
i have a gutted cat and my butt dyno says its a very minimal gain but i had no choice since it was the cheapest option i had while appearing legal lol.
Not really looking at the performance gain factor. When you are sitting on 107hp to begin with, that's really not a factor. A swap a boost of some sort (turbo or SC) is down the line probably, but not anytime real soon.
Looking more at the loudness factor. This is my DD and I do over 100 miles a day for work. Not looking for a Harley or 88 Pontiac Sunfire sound....
it will be quite abit louder with a test pipe also it will be very raspy unless you have a good resonator in the mid pipe but it wont cure all, best bet is to install a short glasspack in place of the cat. i also beleave they make trick o2 sensors that let the ecm see what it wants to see regardless as to what really going on
1989 honda crx si
well seeing as i have a chambered muffler its doesn't get loud at all. when i had a oem cat you barley even noticed the sound if any. now that its gutted its noticeable but not annoying its not even in the cops radar which i like since im in cali. it should be louder though but if you run a resonator long enough it might help.
I think I've decided that I'll grab a test pipe and if its too loud and annoying, I'll just get the hole welded on the cat and put it back on. I'll be out $15 for the testpipe but at least won't have seen downtime.
93 Legend L Coupe.
Gutting a stock cat impedes flow and you will loose power. (No, I am not kidding.)
A test pipe is generally illegal. Weld the hole and go about your life polluting a little less.
1 - 10 of 10 Posts
