Manual gear
Hi everyone, so i drive an honda civic 92 LX, manual transmission and i decided to change my engine to a d13. The problem now is that i cannot seem to locate where the temperature sending unit is located on the engine. The previous one was located under the distributor, but with this new engine, i cannot seem to locate it there. HELP.... :)
That two prong "sensor" is the fan switch for OBD0 cars, not the sending unit. The D12 has it in the same spot as any other D series (under the dizzy) so IDK why the D13 wouldn't have it there too?
Manual gear
So, i took the car to the shop, and the tech said that is the oil fiilter switch. Don't know what to do now....
Dont be retarded Bro.
Where is your FSM?
Where is your Eyeballs and your Brain.
Look, its a one wire sender.
All it does is go to the Gauge Cluster and Does not effect performance.
The ENGINE Coolant Sensor is 3 wire and DOES go to the ECU and NOT the Cluster.
Use your eyes, that's what will find your plug.
Not my ass Sitting in Washington,
Go pop the hood and quit being a Lazy Fuck
The Forum ain't gonna do shit for you.
Take it apart if you must, figure it out.
You can not have all the information I carry in my brain so you should go find some to put in yours.
(By taking it apart and getting real world experience)
