1 - 6 of 6 Posts
89 EF 4wd sedan
Is the thermostat OEM? Does it get up to temp from cold normally? the thermostat is the only thing that will restrict flow to prevent the coolant temperature from dropping too low.
It is a slow mechanical item though, so sudden high RPMS or low load high RPM situations can make most gauges drop before the thermostat closes and restricts flow
D-series SoCal Division
93' dx hatchback
Is the the thermostat installed backwards?
ej2
Discussion Starter · #4 ·
OEM thermostat(78C). Directly from the dealership.
As for warming up normally, it does I guess. The upper hose gets hot as well as the lower hose.
1 - 6 of 6 Posts
