how can i tell if my motor is at tdc and how do i go about getting it there if it isn't?
i assume this i tdc for cyl #1?what motor? My z6 is at tdc when the middle white mark on the crank pulley lines up with the pointer on the timing belt cover. You can pull the #1 plug out too and put something in there to see when the piston is all the way up.
yep, sorry about that :lol:i assume this i tdc for cyl #1?
