i am curious as to what the efficiency of this turbo is on our d-series engines. from the little i know about t3 turbos is that the generally start to lose their pep at around 18psi with the .48 housing. having the .63 housing will this turbo make it to the 20-23psi range? a rough guess would lead me to believe you can get close to 280-300whp on this turbo. anyone?
i did search a bit but i couldnt find any solid info. all i found was one guy running 27psi out of one on his vitara z6 but it did not say what his hp was or any other details for that matter.
D-series WTF?!?!
keep in mind that turbo is like an assistance, with only air too send out how would all that power be use or delivered if a simple motor has oh so much potential!!!
correct sir.
thanks for the input guys.
i see i see!
