I dont feel like searching for this and I know someone has got to have done this before. Installing a tach in a 91 hatchback dx. One wire left to go on my sunpro tach, the green wire. I have heard that even the dx came with a tach wire in the behind-dash harness even though there isnt a stock tach. Is this true? If so, which frelling wire is it?
ABOUT TO GO MADDDDDDDDDDDDDDDDD!!!!!!! CRAZZZZZZZZZZZZZZY MAD!!!!!!!
cannot wire to dimmer switch, Honda uses a ass backwards setup..........
You dim the dash, tach get brighter!!!!!!
Wire from fuse box or the little light for the ashtray, get a circuit that comes on with the parking lights. Wire that through a simple SPST switch, then onto the light wire.
Cruising long trips, you'll want to kill the tach light.
Try having 5 gauges lit on a long drive.........makes you tired faster.
J
jsut stick your white wire off the tach into the fuse box where the fuse is at for the insturment lights, should be on the bottom row, 8th over
i had it wired to the dimmer switch so when i was driving, only the tach would be bright with the shift light but the entire dash was dim. worked for me as it focused attention to the tach.
LOL!! Self hypnosis on a road trip doesn't sound good. That bitch of dimmer switch had me going for awhile till you said that. Wired it up with a switch like you said. easy fix. Thanks
