1 - 11 of 11 Posts
92 civic dx sedan
i have a garret t3 turbo that has an internal wastegate can i just remove the wastgate actuator and use an external actuator or sould i just make a block off plate to cover the hole up in the manifold?
92 civic dx sedan
so its possible then to just remove the actuator and run external? and the turbo i have is oil and water cooled will my water pump give the turbo enough flow?
92 civic dx sedan
That's the answer I want thanks acid il leave the little Garrett alone
Sent from my Autoguide iPhone app
HOnda Ef Civic
if you wana go external gate remove the actuator asembly and get the wastegate trap welded shut if you dont you gonna free boost and thats where the problems are gonna start
92 civic dx sedan
im just gonna leave it alone and if it ends up blowing up ill get a turbo to use with an external wastegate
Black/Green Civic HB
Hey if you want to run more boost you can shorten the arm on the wastegate gate to help gain more boost, but there usually isn't much you can gain ( 1-5psi )
92 civic dx sedan
I didn't really want more boost just didn't know if external was more reliable or better controllable
1 - 11 of 11 Posts
