Hello guys, I have a generic t3/t4 turbo with a larger than 1/8" npt oil feed port.
Anyone care to share some more common sizes found on these?
My turbo came with a restrictor that engages a 1/4" fitting one turn then stops.
Could it be m10x1.25 or m10x1.5 or m12x1.25 and so forth?
Sourced turbo via eBay vendor, I know -3an feed line to 1.5mm restrictor ( about .060" )
Just trying to regulate oil pressure at the turbo inlet without using a cheesy restrictor plate.
With all the different turbos out there. you're better off taking it to the hardware store and finding it yourself. I have 2 garret turbos and both are different, so are the oil drains.
ej8
as said.
Its best to check with where you got the turbo from and start with that size.
When i got my first turbo i must of order 3 fittings before finding the correct one.
I believe most are m10x1.5 tho.
However they do come in all different sizes.
Discussion Starter · #4 ·
The thread pitch ended up being M12 x 1.5
I resorted to using a M12 x 1.5 male to 1/8" NPT female thread adaptor to use my B&R restrictor.
Thanks for updating, but could you add a pic of the turbo in case someone in the future may need this info?
