1 - 20 of 50 Posts
hey wats up. i got a 1991 crx HF. its slow, i think its a an 8 valve motor in it, a pm8. its got a nice clutch and an si tranny with a short shifter. The motor itself runs really good and healthy so i said the hell with it im gonna put my t25 turbo kit on it. Do you think its alright to run 7psi and is it necassery to have like a boost controller and turbo timer and stuff, no right lol. i got an hf exhaust manifold, t25 turbo, bov and a side mount intercooler that im gonna turn into a front mount bc i got mad extra piping. do you think this will work good and have some nice power. thanx for all the input.
id run 12 psi from that dinkass t25, im running the same turbo, id up to 12psi but im running stock exhaust for now so ya.
so i can run 12psi on a stock block and where do i find the stickies lol im new to the site. thanx
97 civic
you will also need a way to tune your engine......i.e. add fuel ,adjust timing.
lol yea i absolutely hate my motor but moneys tights these days so unless i can find a nice cheap SI head, im gonna just deall with it lol. So as far as tuning i was goin to have the ecu(pm8)tuned, is that bad or wrong.
Lifetime Awesome Member
'89 CRX HF
you are wasting your time with that motor. will it run? sure. will it be worth it? probably not
stock fuel cut is 5500, and its there for a reason. the motor WILL NOT make power above that, even with a snail. so lets say that with this 8 valve piece of shit, you are getting full boost at 2500(it will probably be later), now your torque curve will flatten out at 5500 even though the turbo is able to make power above that. you leave yourself with 3000rpm of usable power, and when you shift that low, you are going to fall out of boost.
at least swap in a mpfi DX motor or something. the HF is a joke
SI head wont work on that block with those slugs in it. the pistons have 2 valve reliefs, and they need 4 for there not to be valve interference with the pistons
absolutely tru but i have a mpfi motor so is that the dx motor i dont know the motor code i think its d15b7 or sumtin. Im just goin to do it bc it will be faster then wat it is now and i already started so its w.e but thanx for the info.
Discussion Starter #16
the DX doesnt have to stay dpfi, it can be easily converted...
nah my car is converted already. Its not dual point, its multi point.
Discussion Starter #18
any good tuning programs, i was goin to go with crome???
Discussion Starter #20
hf chassis already have multi-point harness in it. so it was never converted.
o0 lol tru wasnt sure thanx for that info. :hammer::p
1 - 20 of 50 Posts
