Does the Turbocharger have any shaft play?
not even the slightestDoes the Turbocharger have any shaft play?
neither, actually. its kind of like a smaller version of a t3 flangedoes the turbo need a t25 flange or can it be used on a t3/t4 flange??
^^Yup, I went with something bigger (CT26neither, actually. its kind of like a smaller version of a t3 flange
it was pulled off a John Deere tractor because the dealership thought it was shot. turns out the oil return line was pinched causing oil to be pushed past the seals. it only has MAYBE 3-4hrs of use(engine breakin), and ended up working just great after the return line was fixed
good info, i never tried it on a t25 flange, just figured it wasnt rightIts t25 flange should be right, it lined up on my greddy manifold. If it were any tighter it be virgin!
