1 - 20 of 21 Posts
99 accord ex/ 98 ek
i know that the t25 is a very small turbo which spool pretty fast and max out at 250 hp 14 psi.
i want to know if i cant run this one in a stock internals.
i getting a d16y7 with 70k miles on it, ( same engine i already have but with wayyy more miles)
i was thinking maybe 10psi DD
will i need to replace the valve springs ( ferrea),cams(bisi) and cam gear( AEM). and a y8 IM for sure.
will the stock piston and rods will b ok? or i should get different ones.
im still looking for a tranny (y8)
dont tell me to search because i did and found info here and other forums, but i would like to know if somebody here have a t25. i would like to know for personal experiences.
thank you
I'm telling you to search.
Will 250hp on stock internals be a good idea?
Well would you look at that, I found the answer in 4 seconds searching.
Also why would you need to replace the cam and springs to support 250 on stock internals???
You gotta search kid, no other answer than that....
Try a search.
1990 civic 4 door LX
More people make more power than that on stock internals. If you searched you would have seen in every thread they say 200-250 is about "how far I would go".
Also. Search and learn. Then make posts. This is useless. Yes you can turbo stock internals. No mode to engine. Put the turbo on. Tune. Set plug gap before that. And your good.
When someone makes a post and engine is stock. They don't mean stock. They mean cam gear. Sprinhs. Retainers. Cmon man. Common sense. Stock is stock.
99 accord ex/ 98 ek
im not saying that i will push it to 250 because i know i will need stronger rods and pistons, cams and valve springs.. i think i should be more clear. how must boost will internals take with a t25,anybody here running that.
you need to search how turbos make power and how a car internals except boost.... just to answer you so this stops dont go over 10.. but i would stay at 7-8 so you dont fry rings or brake a ringland now go search and learn cuzz you no nothing
99 accord ex/ 98 ek
and yes i want 250 hp but since the engine has very low miles i thought that may be able to hold better, and no need to get new/better pistons
thank you
Stock internals with a T25 your looking at 6-8 psi and 8 psi is pushing it, I wouldn't push it past 220 hp on stock internals your going to either melt your pistons or put a nice window in your block
Word.. the search will lead you in the right direction. Google. " stock civic turbo" bet that alone gives you all answers. Look ar turbo installs. Our guys are detailed ejought to tell every step
99 accord ex/ 98 ek
all right guys i think i was asking this the wrong way. i was looking for personals experience on how is your set up holding on stock internals
most people know that shit will only take a beating for so long at so much boost just boost your car have it tuned and when you break something fix it
90 crx si/96 accord
the connecting rods are the "weakest" link in the engine. address the bottom half before spending money on cams and a cam gear.
doesn't make sense to me why you would spend money on the valve train when the limiting factor would be the bottom end
99 accord ex/ 98 ek
I will buy pistons, rods, valve, valve, springs and all internals little buy little and push it to 250- 300. But now I just want a t25 with stock internals at 8 psi, 180-210 whp, that's why I would like to know how ur set ups are doing.
I already have the turbo ( just tubo) so all I will need I'd pipes, injector n tune.
ej8
Wow. Just wow.
REally if your search you can find a shit load of information. Also you never said what kind of t25 your using there is a ton of them out there so that will make a difference also.
But simple answer tune her to 200hp and call it a day on stock motor.
If you have a healthy motor. Throw in vitaras and rods. Go to 300 Qiu head studs. That's about as good as its gonna get.
With a proper tune 180 whp depending on torque isn't pushing a good bottom end. Hey aren't sweating at 180 to had. My d15 rods did 220wtq before bending.
Pistons are Tue weakest link unless you can keep the heat away. Proper tune. Ign. Fuel. Otherwise I see more people cra k riglands. From abuse obviously. Hammering.
90 CRX Si
Springs and retainers will be fine stock if you're not turning a lot of rpm, and with that turbo you won't wanna do that anyway. Weakest point is rod bolts and rods. If you want, add ARP rod bolts for a little extra insurance.
99 accord ex/ 98 ek
Discussion Starter #19
I think is from a talon, my friend and I pulled long ago and never used it.
That's what I was wonder is the oem pistons will hold, because I think they are really weak
hatch just search for real dude all this shit has been answered several times... go on google.com and type every question you have one by one and you will find an answer... once you get two or three answers for your question come back and ask witch answer every one thinks is better
1 - 20 of 21 Posts
