1 - 4 of 4 Posts
Same as above
Ive got a GSR trans that grinds in 2nd all the time. Unless you're at a stop theres no going into the gear without grinding. So i skip it all together. Ive got an LS trans that had no problems grinding. Can I take the single cone synchro off the LS trans and replace the dual cone synchro in the GSR? Or will I just have to fork out the $75 for a new replacement dual cone?
You would have to change the gear, hub, sleeve.....and still wouldn't work.
Also synchros don't grind, plan on replacing the 1-2 sleeve as well, $149 retail from Synchrotech, Chris/Aquafina likely has them as well.
I might have a used one on hand from a carbon install, but you have other issues, including the spring ring.
1 - 4 of 4 Posts
