21 - 32 of 32 Posts
i just bought hardrace itr endlinks to go with a ctr bar... wasnt sure if it was going to work 100% but this writeup confirmed what I assumed would work... thanks a ton... and i must say d-series has a ton of info good job kids =P
96,97,00 civic
Awesome Post man!
short answer for most of us though, Add a big one on the back and remove the front one, this method has proven it's self over and over.
I have the USDM ITR rear sway on my ek, what sway bar bushings do I need for the bar? I see the endlinks I need (aftermarket or oem SI) but need info on what bushings for the bar.
Thanks!
Well?
you need 22mm bushings. either ES or just factory ITR
installing 97 EX LCAs and the 26mm eibach front swaybar on my 96 dx took maybe an hour. super easy and painless.
I have a canadian Acura 1.6 EL 4 Door (4 door EK)I'll add the sway bar info once i measure them the car comes with Front and Rear sway bars from the look of them they are the same size as the SI or canadian SIR
I'll measure to be sure and you can update your list
96 Civic 4dr
Do you know if the 1st gen CR-V 24mm swaybar is compatible with the EK's I've heard it is since they share a common chassis but I don't know of anyone to try it. If it is are the factory mounts spaced enough to bolt it up?
21 - 32 of 32 Posts
