1 - 7 of 7 Posts
Honda Civic
I had this idea going around in my head and I wonder if it's actually possible and worth trying. I've been thinking about finally doing some engine mods (nothing fancy, just probably Stage 1 stuff) and one thing that I want to try to stay away from is louder exhausts. Sure, they might flow better, but I really want to maintain my semi-sleeper illusion.
I've been thinking about possibly getting an exhaust from another Honda model and swapping that for my stock one. Like, basically get the exhaust from the cat-back. Would there be any OEM Honda exhausts out there that would work well paired with, for example, a DC 4-2-1 header? I have a friend with a welder who completed fab school, so cutting and welding flanges isn't such a big deal.
D-series SoCal Division
93' dx hatchback
In my old setup D15B vtec in a EJ1 I ran a RSX type s resonator and muffler.
I bought the whole cat back from a salvage yard for like $40 so. Went to a muffler shop had them retro-fit it into my car 2" piping all the way. What a difference in power compared to stock and was quiet as f*ck.
Honda Civic
Whoa nice! So basically, if I get an exhaust from a higher performing model, I'll be in good shape. But I assume I shouldn't go with one that has too much flow or I'll lose power right?
ej8
Get and si b16 exhaust and mod it to fit.
Or just get and eBay 2.25 exhaust and a good muffler. Twin loops drop the noise or even get a stock si muffler and weld to the end.
I see your in CA a emissions will be ttough. You might wanna just get an si setup.
97 honda HX-07 STI
I was curious about this. One thing I can tell ya and I have heard a of a lot people doing them. But The DOHC ZC motor Header pipe will bolt up and breaths a lot better. And as far as the sleeper idea that is cool going around and saying yea just a stock D series. That is kinda what I am doing. However I did fudge on a aftermarket header. So far what I have done is on a mini me D15B7 bottom end Z6 head( I am going to do the 3 layer mod when I reinstall a new head gasket) Y8 IM and Aftermarket exhaust 2 1/4 exhaust. I am going to install f22 Vtec injectors and high flow fuel Rail and F22Vtec TB. And u can bolt up Y8 valve springs and they are stiffest stock springs u can find. Again key here is stock and if you can find a D15ZC Vtec motor (Note VTEC-E) it has the most aggressive cam profile out of all the SOHC cams. Then when it is all said and done. A good tune. Maybe lightened flywheel and Crank pulley. I think it should net 150 at the wheel...Maybe not sure but that is where I am going. Also you can shave the head I have heard. But if u do the 3 layer mod then it will need to be less.
94 Integra
An oem exhaust is an oem exhaust, it has little impact on emissions if you have the correct converter. In the end, a pipe is a pipe and many people sell their OEM exhaust with low miles when they upgrade.
If you look on youtube, you'll find a lot of Civics & Integras with non-civic/teg OEM exhausts. I got a 06+ Si exhaust for free, so that's going to be used on one of my cars, and I was about to use an AP1 muffler on another car til I found a mint OEM GSR axle-back. Only the del sol & hatchback civics are hard to retrofit, since there's much less length before the bumper.
One muffler people used in the past for higher-HP Honda street cars was a single-exhaust 2JZ muffler. It would flow as well as an aftermarket muffler but sound like stock. They're hard to find since they haven't been made for years. I'm sure there's a lot of newer options given so many "plain jane" cars now have powerful engines with single exhausts.
Honda Civic
Sound like I have some options to play with now! I'll probably look for Si exhausts or Integra exhausts. I feel like the ZC exhaust might be hard to find...
1 - 7 of 7 Posts
