1 - 3 of 3 Posts
I've been doing a lot of searching on here and around the Web and nothing is really coming up for me except on a few hypermiling sites. I see a lot of people dropping the D16Y8 their 96-00 Civic HX cars but never anyone putting a D16Y5 into their 96-00 EX.
I'm pretty particular about my mileage so I keep a pretty good running total on what I get. Right now, I average 32.7mpg in my Y8 running 20% city / 80% hwy @ 65-70mph.
Again, being mileage friendly, I started to do my research about what I could do to get better mileage. Upon my research, I found that A LOT (meaning 70% or more) of the mileage people are getting out of their 96-00 HX is 40-42+ mpg. I've even seen readings as high as low 50s.
My thought is: what mileage could I get if I swapped an HX motor into my EX Civic?
I would keep the EX transmission and just buy what I need. So far, I understand that I need an HX (D16Y5) engine with complete intake and exhaust manifolds, a new wideband primary O2 sensor (HX is 5-wire, all others are 4-wire), D16Y5 wiring harness and HX ECU (P2N code).
I also understand that the HX motors were all OBD2A from 96-00. So, would I need some kind of jumper harness to make the HX computer work, without a check light, in my '00 EX (OBD2B)?
What's everyone's thoughts on the mileage I might be able to get with having the HX motor but still having the EX transmission? How much would having the EX transmission hurt my gas mileage?
I hope I posted this in the right spot in the forum. This seemed like the most appropriate place. Please let me know if I should move it to somewhere better.
Thanks in advance! Have a great day!
Love the Civic
Don't use the HX harness. Reuse your EX and modify as needed. Because it kept the OBD2A ecu layout it won't be compatible with your chassis. Use a OBD2B to OBD2A jumper harness.
1 - 3 of 3 Posts
