Civic CX
my drain plug in my oil pan was stripped by the PO and i bought a new one and plug. what all do i have to remove to swap it out? from the looks of it theres a bracket with like 4 bolts then part of the exhaust and let it hang down? just want to get an idea of what i'm in for before i start taking stuff off. every post i see about oil pan swaps just says easy unbolt and bolt back on :nono:
Civic CX
but the problem is i can't get the old plug out. it just spins in the hole no matter if i try to tighten or loosen it. i've even tried a flathead under it but now the washer got frayed under the bolt.
