1 - 4 of 4 Posts
So I swapped manual transmission from dx to ex. Went to hook up the battery and the cables almost welded to the terminals. Check all 3 grounds, both sensors on trans. No idea what going on
Has anyone experience anything like this? Or where I should start with looking for the short?
sounds like you grounded out a positive wire. trace em back
Reactions: robgoof
Discussion Starter · #4 ·
figured it out. Post on the starter was loose and grounding itself out. Fried the starter. Luckily it was under warranty. Put the new one in and it runs like a champ now.
1 - 4 of 4 Posts
