1 - 4 of 4 Posts
8
I have a 86 crx si with a bad motor and i was wantin something a little more powerful than my d15 and i was wonderin if the zc would bolt right in and cuz i use my si transmission because it is brand new and how quick would it make my car
im not sure about the tranny, but you are going to need different engine mounts, and depending on if an actual ZC, or a D16a1, the zc will make your car a bit faster, but finding parts and having to modify it to make it work with obd0 or obd1 could be mandatory, the d16a1 is kinda along the same lines power wise as the d15b7.
1 - 4 of 4 Posts
