1 - 7 of 7 Posts
Found this turbo on ebay. Its off an SVO mustang and the listing says the wastegate hole is ported. any info?
"How many PSI can I run on stock internals???"
It's definitely a bigger turbo. It will need a set of forged rods to be properly utilized.
Will be laggy too.
I wasnt askin how many psi. lol. but you did answer my questions. i didnt really think i would be able to find it in the stickies since its an svo turbo. thanks.
Ran one, loved it. made 208 whp and 173 tq on 12 psi with my y8. I have a dyno sheet if you'd like to see also. I was able to reach full boost at around 4000-4500 rpm. Started spooling at about 2500-3000 rpm.
It's smaller than the Chinese t3/t04e I am running (along with a lot of other people), and mine spools 8psi at 4500. This should spool that (and maybe more) by 4k.
While not a small turbo, I would not call it a big turbo. It would be similar to running a big wheel 16G. It is a good turbo that will make 200whp without being laggy like a t3/t04e, but is capable of making 300whp (ish) if you decide later that you want more power.
The ported WG port is to keep it from creeping.
I am switching out the t3/t04e I am currently running for the same turbo. Take a look at TheAssassin's build thread. He is using a similar turbo, but with the .48 exhaust side. Your .63 turbine will spool only a couple hundred rpm later.
http://www.key-ideas.com/T3T04ETurbo.html
This site shows the difference between the t3 60 and the turbo a lot of other people are running.
I used a t3 .60/.63, externally gated on my old built a6 at 15-18 psi and it was perfect for the street, not laggy at all, and pulled crazy through the entire gear, highway runs were nuts.
I still have the turbo in perfect condition, but because its sat a while Ill probably have it rebuilt / checked
Its a sick turbo, but genuine ones generally arent cheap
1 - 7 of 7 Posts
