1 - 20 of 39 Posts
Vitara it is. Zealworks has the option of choosing Vitara pistons on the compression calculator!
He sure as hell hasn't been around here...
Search for Vitara builds... plenty of the D-series people are using them and member fjt sells them for about $130 shipped. :tu:
EX coupe
hahahaha......no but really though.....is it the engine that sounds like a Diesel or the Turbo....lol...
Your mom sounds like a diesel... :D
But seriously... she does :shocked:
same^^^
The issue isn't with the pistons... It's with the retard that machines/assembles the block. Use a dial-bore gauge to find the size of the bore. Use a micrometer to find the diameter of the piston skirt. Subtract. There's your clearance. Double-check with feeler-gauges. If it's much more than Honda's recommended tolerances(about .003" I beleive), buy oversize pistons, bore, hone and get the right clearances.
Don't blame the pistons for not fitting your 130,000+ mile block. Blame yourself for not buying .010" oversize.
-josh-
^^^^HAHAHA^^^^^ Stupid junk pistons.. Whose the douche bag that milled these up. I bought these 350 pistons for the D because I wanna make 400hp!
1 - 20 of 39 Posts
