1 - 9 of 9 Posts
crx
Guys I am having a problem trying to figure out my surging idle problem. I am running a zc dohc with a jrsc lht upgrade.
Here are the things I have tried.
New Iacv, tested the wiring also
new tps
new water temp sensor
Bled cooling system numerous times..
Tried another ecu, I am using Chrome
Preformed a smoke test did not find any vacuum leaks.
The strangest thing about this problem is once the car hits 150 degrees it will start surging but after if gets a little warmer the idle gets smoother and the surging stops. Any idea on what going on, this car is driving me nuts.
Do you have the fast idle valve? If so that can be causing the surge.
crx
Discussion Starter · #4 ·
couple of things.
does your your jrsc have the bypass valve? and is it working?
will it idle fine with a stock ecu?
i would guess it to be in your tune i had that issue when i was on chrome as well. never got it fixed till i was on neptune so not sure what caused it for me.
civicdxude
Yes it has a bypass valve, it appears to be working. It still acts funny with the stock ecu but much better. I have heard that chrome can cause idle issues also . I am thinking of upgrading to Hondata or neptune. I really do not like how its idling, just does not seem as smooth as it should be, maybe its the blue dsm injectors(I had them tested and cleaned). I plan on upgrading next year with more boost.
2jzdreamin
no fast idle valve
Meat Popsicle
91 CRX Si
The bypass valve won't affect the idle, even if it is stuck closed. I had a non-working bypass valve in place for years before I realized that it was stuck closed the entire time.
How is the PCV port on the S-tube plumbed? You sure all the vacuum ports on the manifold are either connected or capped? Make sure you double check the 2x ports on the back of the S-tube/supercharger adapter.
I run cleaned and flowed DSM injectors, as did a majority of the people who ran these kits 20 years ago did, and I haven't had any issues.
crx
Pat
PCV on the s-tube is blocked off, I am running a catch can from the black box and valve cover. I completely forgot about those 2 ports, I am sure they are blocked off, I think one runs to the bypass valve? I did run a smoke test on it and could not find any leaks and my smoke machine puts out a lot of smoke.
Thanks for the suggestions
crx
Discussion Starter · #7 · (Edited)
Guys I fixed the surging idle, turns out I had a pin hole leak in a coolant hose. Air was getting into the cooling system.
Now I have a weird issue with the car running lean at idle it fluctuates from afr 14.9 to 15.8 at idle and its running a little rough.
Meat Popsicle
91 CRX Si
Hrmm...how was air getting into the coolant?
Anyway, the AFR thing definitely sounds like a tune issue. I would datalog at idle and see what's going on. Is it holding a steady vacuum?
crx
Discussion Starter · #9 · (Edited)
Pat I figured the pin hole was causing an air pocket, maybe it was the wrong way to say it. All I know is it stopped since I fixed the leak, lol..
Unfortunately I did not tune it and do not have any experience tuning. I had it dyno tuned at a local shop. The vacuum I believe is steady but a little low, I am running colt tri flow cams and the base idle is set a little high 1000rmps. I will double check to see if if it holds a steady vacuum.
1 - 9 of 9 Posts
