1 - 6 of 6 Posts
This is the set-up I was thinking about going with down the road but, I'm not sure what the compression ratio would be assuming stock headgasket thickness and y8 chamber.
If anyone knows that would be awsome.
B16A Rods matched with non-US Supra 1G-GTE pistons:
I calculated the following #'s for this combo
Piston volume = -7cc dish
Compression height = 33mm
Rod length = 134mm
Thanks,
Chris
insert user title here
old as hell.
vitara / eagle tt rods combo is cheaper while making more power.
its called the turbopanda setup. named after turbopanda from hondatech
1 - 6 of 6 Posts
