1 - 4 of 4 Posts
This may sound like a foolish question, but would anyone have any input on running a s/c d16y8 with a lightweight flywheel? I know the light flywheel is never a bad investment, but through some online digging I've found people saying that the light wheels are easier to crack. I was planning on running an s/c with like 5-6 lbs of boost. My concern would be with all that low end power from the s/c, would it be risky to be dropping all that power on a lighter wheel? Like I said, this may be a dumb question to ask, so only weigh in if you have something useful to say
It's rpm not torque that shatters flywheels.
The strength of a flywheel depends mainly on what it is made from. High grade steel or aluminium can make a very light flywheel that won't shatter. OEM flywheels are cast iron. It can shatter at high rpm, especially if it is to thin.
A point you don't mention is that a flywheel is also a heat sink for the clutch. If you overheat it, first the clutch fails, but also, you can create cracks from the sudden build up of heat.
Did you have your OEM flywheel cut down or did you buy a aftermarket flywheel what is the weight and what material is it made of?
1 - 4 of 4 Posts
