1 - 1 of 1 Posts
Vendor
Rear spoilers are one of the most popular auto accessories available on the aftermarket. From mild to wild, a rear spoiler can change the entire look of any vehicle. If you want the spoiler, which after mounting has a factory installed look, then the factory style spoiler is exactly what you need. We have 2 exclusive options from T5i and Pure, which you might find interesting.
T5i® - Factory Style Flush Mount Rear Spoiler will perfectly complement your car's fine lines, and its distinctive shape will set your car apart from lesser models. It delivers a sporty image that is easy to be recognized. Made from ABS plastic, installs easily with 3M™ tape and screws, backed by a 3-year warranty. You can use it for better traction and to add a sporty look, but also include other advantages, such as increased fuel efficiency, added visibility, reduced car weight, and braking stability.
Pure® - Factory Style Rear Spoiler with Light enhance vehicle's exterior as well as improve its maneuverability. It helps to give your car the same look as the high-performance models. It improves aerodynamics, has factory style, made from Fiberglass and installs easily with screws and gaskets. Also a 3rd brake light is included, for increased safety.
Both spoilers are available in Unpainted and Painted versions (you can check the paint code by VIN# or with paint code labels, located at the driver side door jamb).
Discover more about those brand here:
T5i http://www.carid.com/t5i/
Pure http://www.carid.com/pure/
Check prices for your model and see other details here: 2014 Honda Civic Spoilers at CARiD.com
And which one would you get for your 4-wheel baby?
1 - 1 of 1 Posts
