1 - 20 of 20 Posts
S
didnt think there were many...no interest in being one of the first either, there goes supercharging the d. I didnt really want to supercharge either(for some reason).
K
I have a Supercharged Y7 and I like it a lot. Provides instant power and it is very reliable. Don't have any numbers yet, but it pulls hard.
O
most guys get about 185-200 wheel power on a sc with about 9-10 psi. the jrsc after that can't really push more with out major mods beause ti over stresses it and over heats the sc itself. the vrotech get more, but it takes more to get equil to that of a turbo setup, and a sc costs more. the advantages i see if you were wanting to autocross woud be to get a jscr and get a 9lb setup. and leave it. at about 185-200 wheel power it would be decent autocross setup.
S
Yeah, supercharge only for auto-cross. When I was thinking about boost, I did some research, and turbo is way better for the money. It's so much more efficient, and you're not always under pressure, only when you really want it.
Now as a suggestion, IF you are looking for a no-lag, low end kind-of setup, a small turbo can bring that. I know that the VW turbos (1.8T and TDI) are spooled before 2700 which is the begining of the powerband for a Honda anyway. You'll probably top out at 185whp with a turbo that small, but hey, that's still pretty quick for virtuallyno lag.
D
instant power huh... if you raced a replica of your car with 1 sc and other turbo at same psi.. turbo will win, no doubt about that.
lets just say if you were supercharging and your redline was at 6000rpm.. and your boosting 6 psi.. you ONLY get 6psi at 6000rpm.. and 1/2 of that you get 1/2 boost so at 3000rpm you get 3 psi and then increase .5 psi per 500 rpm... and a turbo will reach full 6psi at ~3500rpm. so which one would be faster??
K
I don't know where ya got this from but my Autometer Boost gauge says 6psi when I stomp on the gas. Someone said something about boost when ya want it. The Supercharger is the same way, it has a bypass valve that eliminates boost when you don't need it i.e. cruising on the highway or just regular driving. For a daily driver the Supercharger is great.
full boost comes on after 3500 rpm ... jr sucked ass.... 139hp 116ft/lbs with stock everything and running super lean 17.5....lol but now it should be more with upgraded pump...etc...etc and still upgrading ... save ur $ and go turbo or swap it's no bolt on kit
O
draztik, your thinking blower type Sc JRSC is a roots type, they can boost full 6 at 3kon and hold it. but you do have to remember it takes power to make power, so your really only equil to a 4psi turbo setup at 6psi sc numbers doe to hp needed to make it go faster
C
Discussion Starter #16
If I'm able to make a custom supercharger for B-series motor. I can someday make a supercharger for the D-series motor.
Supercharger vs Turbocharger both works the same way. Except Supercharger use pulley to drive the turbine while Turbocharger use hot exhaust gases to drive the turbine.
Supercharger - No maintenance
Turbocharger - Maintenance required
Both can provide higher boost contents.
T
Here, I stole this post from Club Civic's forum, they are a bunch of air heads, but they had this posted up..................
"let's start with the basics because quite a few of you believe myths to be true, and truths to be myths. Listen closely... I'm not going to speak from opinion, but provable facts and first hand personal experience. This post will be THE definitive post in this thread.
CSC = Centrifugal SuperCharger.
SC = SuperCharger
Turbo = Turbo.
OK, good. Let's start with efficiency...
Both turbos and superchargers compress the air and force it into the engine. In doing so, they heat the air, and this is the measure of efficiency- the less heat, the more efficient. There are several design factors that affect the thermal rise of the charge air- internal aerodynamics of the compressor (I'm referring to turbo, SC, and CSC), internal surface area, and the number of direction changes the air has to make. Hands down, a centrifugal compressor (turbo and CSC) wins this contest. It has less internal surface area, the air has to make less turns (it really only makes one turn), and due to the design, it is FAR more aerodynamic. Roots type compressors like the JR units will never see more than 55% efficiency. Centrifugal compressors can have efficiencies as high as 80%. The less heat you make, the higher the detonation threshold is. The higher the detonation threshold is, the more boost you can run. The more boost you run, the more power you make. With the Roots compressor and its lower efficiency, it feels slower because it's making less power. What do people do? They turn up the boost with different pulleys. What does this do? It makes more heat. What is a not so obvious consequence of heat in a Roots compressor? Decreased clearances between the rotors and the housing, as well as thermal expansion of the rotors themselves. The rotors can expand to the point of cracking and shedding their ceramic coating, as well as grinding away some aluminum from the housing. Guess where all this stuff goes next? Even if this didn't happen, you're limited to about 12 PSI in an unmodified Roots compressor due to thermal rise. Above 12 PSI, you have to add so much fuel and retard the ignition so much to overcome the heat- induced detonation, that you start to lose power. The cost of modifying a Roots compressor to achieve power above 12 PSI outweighs the actual gain in HP.
Now let's talk about lag...
Yes, turbos have lag. This is not bad, however. First off, though, let's look at why they have lag and why the lag is good. Turbos have lag because they are not an RPM based device. That is, they are not confined to a set speed dictated by crank RPM like an SC and CSC is. Why this is good is that it'll only give you the boost when you need it. The SCs are boosting all the time, constantly drawing power from the engine. The reason you don't see boost at partial throttle is because they have diverter valves to bleed off the boost when the engine VE doesn't need it. Basically, you're making power and throwing it away without using it. Kinda like buying gas and then dumping it out on the ground. At partial throttle, the turbo is spinning along, but not fast enough to make boost because it's a CFM dependent unit. The more air the engine can move through itself, the faster the turbo will spin. Off boost, you retain stock drivability and gas mileage with a turbo. With an SC, you gain a touchy throttle and wasted energy. Another great thing about the turbo and it's lag, is that you're less likely to have traction problems right off the line, and in a light FWD car, this is paramount to performance. With the advent of modern aerodynamics and ball bearings, turbo lag has pretty much been eliminated above 2000 RPM with the proper setup. Sure, the JR unit boosts 2 PSI at idle, but who drives around at idle? I don't. Do you? With a proper, thought out turbo setup, you can have little lag and haul ass top end, and virtually zero lag from the midrange on, and when you're racing, this is where the performance counts.
Now, if you'll noticed, I haven't mentioned the CSC at all in this part. Why? Because it combines the worst of both worlds- the parasitic drag of a supercharger, and the turbo lag of a grossly mismatched turbo. Now, since it's a supercharger, the compressor RPM is a fixed value of the crank RPM, meaning, if the crank is turning X RPM, the compressor wheel is turning Y RPM. It is a linear relationship and never changes. Since the CSC uses a centrifugal compressor like a turbo, the boost pressure and CFM rate increases proportionate to compressor RPM. That having been said, the faster the compressor spins, the more boost it makes. Since you don't want to over boost the engine (let's say for the sake of argument, the max. boost pressure is 10 PSI), the maximum boost pressure RPM is reserved for absolut engine redline. If it were set for 4000 RPM, the engine would overboost above 4000 RPM and blow up. Now, since the boost pressure is only achievable at absolut redline, the boost pressure rise is a function of the square of the crank RPM, that is, at half RPM, you'll be making one fourth of your maximum boost pressure in the case of a B16 set to run 10 PSI, that comes out to 2.5 PSI at 4000 RPM. Compare this to a modern turbo that will make 10 PSI by 3000 RPM, and I'm sure you'll see why Vortech superchargers havn't taken the import world by storm. I'd rather wait a second for full boost, than to wait 'till redline.
Cost vs. HP...
For this comparason, I'm going to use a D16Z6 in a 5th gen hatch because this is where my personal experience comes in.
I spent around a grand on a budget turbo setup for my '93 Si hatch and ran 10 PSI. I saw positive pressure as low as 2000 RPM, full boost by 2700 RPM, and above 3300 RPM, I had instant full boost when I floored the pedal. A friend of mine had an '89 base model Civic hatch with a Z6 and a JR SC in it, for which he spent about $2600 on just the blower. We were both running FMUs, and he was running 10 PSI as well. He had a weight advantage of about 300 lbs. Off the line, he had me. For about 10 feet. By the time I was at 4000 RPM in 1st gear, I was next to him, and by redline, he was at my rear bumper. By 100 MPH (roughly a 1/4 mile for me), he was a good 30 yards behind me. I have no idea what this equates to in HP difference, but a 90' lead at the end of the 1/4 mile is considered a solid trouncing.
Conclusion...
SCs have their place- low RPM, high torque applications such as two stroke diesels found in cranes and graders. Turbos do too- under the hood of a car owned by anyone that's serious about going fast. CSCs have a place too- the Dumpster."
Dont go on to say that top fuel dragsters use sc's so they must be good, its becuase of the rules of their class, like nascar uses carbs, solid axles, restrictor plates...class rules."
This entire post was stolen from Club Civic by myself, a quote from some schmoe......
A
Discussion Starter #20
That was a very similar article you wrote, one of the sentences in it was identical other than the grammer and spelling errors :wink:
1 - 20 of 20 Posts
