1 - 9 of 9 Posts
on my ej1, it needs some help pushing it up while holding the button. seems to be a common problem
Look up and download a service manual for your car.
In it you should find if honda put in a manual mechanism in case power was lost or the motor gave up.
At least you would find out how to remove the headliner and access the mechanism so you could pop everything shut.
there is a nut on the motor to do it manually, but I thought that was strictly for closing it. check the relays?
Checked the relays... nothing heppend they Ok.
the nut is stuck or something i wont breake him..
i tried to clean all the rail and nothing....
the cable looking good
theres a diy somewhere on Honda-tech on how to take it apart and thoroughly clean it and inspect it.
Ferio inspired
90' Civic sedan
check to make sure the brackets that move aren't cracked. Mine is and it won't let the moonroof go back in, only up and down.
I also tried using the manual way, and it is jammed since the plastic bracket is broken.
Discussion Starter · #9 ·
ok i will try to disassemble and clean it
will update later what i found :)
1 - 9 of 9 Posts
