1 - 2 of 2 Posts
1997 Honda Civic DX
i have a set of 12s n my car and my old amp blew so i replaced it with the same amp as before, but now its doing weird stuff. if you tap on the housing over the stock speakers from which the input is run from the subs will play the noise. regardless if the deck is on or off, it will do this when there is power running to the amp. it never did this before with the old amp and all i did was swap the wires from one to the other. is there something m missing here or what.
I think it might be a bad ground connection since on old tape decks i used to have if there was a bad ground you could hear the engine go vrooooooooom through the speakers themselves but yea check your ground make sure that is tight and check your inputs make sure they are in the correct plug ins dont ask me how many times ive done that before.
But mainly i think its just your ground cable has either weakened its connection to whereever you hooked it up to (just sand it some more I guess. or just a bad ground all together.
1 - 2 of 2 Posts
