i just replaced my valve stem seals and car ran fine then i filled up with 93 because i was told i was running too lean and i figured it couldnt hurt to clean things up now ive got no power and my car sounds like a harley any ideas why, im thinking bad gas but i tried a fuel stabilizer and still stumbles
J
try also cleaning the combustion chamber mopar and other oem manufacturers make combustion chamber cleaner you pour it thought the spark plug holes, and then your run the car for a while and it burns out the carbon deposits (sometimes the carbon can acutally absorb some of the fuel, and cause a lean conidition in an otherwise working engine) also check your fuel delivery system, ie injectors are within spec, and fuel pump okay etc....
-juan
thanks really appreciate it, im a try that cleaner you talk of, sounds like what i need but the problem i found was that my first plug wire was burnt halfway up the boot causing the spark to only work halfway, replaced the wire its all good but im still burning a little bit of oil, i think it could be still be whats built up in my cylinders so im a try that cleaner, oh yeah the timing is straight we did that when we messed with the valves do i need to reset the ecu still if no light comes on, well i always have the vss light because my speedo dont work.
