1 - 2 of 2 Posts
FYB or FIU tune, pick 1
95 Del Sol Si
Ok so ive been tuning on crome for some time now... last logged into here like 2011 or so, its been forever and ive learned alot. Anyways, i recently acquired a 12" laptop for tuning and due to the smaller screen its harder to see. Is there any way o can expand or make the map/tavles bigger? The tables start at the upper left corner and go about half way down and half way across. When i add boost tables it goes farther across and this is fine especially while datalogging, but i was wondering if theres anyway to expand the tables more? Like drag/stretch them to fit better mainly pulling them down more or fitting them solid to the window size in crome. Theres a run in full screen option in crome but this is no help as it boxs in crome with a blacked out strip on both sides of the program. Any help is appreciated thank you.
1999 Civic EX Coupe
There are no settings in the Crome software to do that from what I can tell. The only solution to your problem I can think of is to decrease screen resolution on your laptop a notch or two in windows to make your table fill the screen more.
1 - 2 of 2 Posts
