1 - 1 of 1 Posts
same as above
I have a 96 civic hx that I just recently replaced the head gasket, timing belt, water pump, tensioner, spark plugs, air filter, and thermostat. I go to take it on a test run, the car was warmed up for about 15 mins. I leave my street get going about 45 just staying at a steady pace and when I barely lift on the throttle the car starts to stumble/jump/misfire type thing it goes away in a second though if you hit the gas. I cleaned the iacv. No cels unless the bulb has been removed. Any suggestions?
1 - 1 of 1 Posts
