one of my strut is goin out and a buddy of mine recomended a (i think its) KYB or KYG somethin. but he described it as having a 1.5 in. shorter rod. i was jsut wonderin if anyone else has hear about these..
Close, the shorter stroke is to prevent damage to the dampner. If you run stock length dampners with lowering springs you run the risk of damaging the shock if you bottom the suspension out.no, the shocks are made for lowering springs/coilovers... they are shorter so there isnt a gap between the top of the spring and the top of the shock when you jack the car up.
+1 I have KYB 4 way adjustables and highly recommend them to everybody.Close, the shorter stroke is to prevent damage to the dampner. If you run stock length dampners with lowering springs you run the risk of damaging the shock if you bottom the suspension out.
