1 - 20 of 51 Posts
spec V /Mach1
I know its probably a noob question, but I searched and didn't get an answer just suggestions for aftermarket stuff. I was wondering what was the strongest oem replacement connecting rod we can use on a D16? Thankx guys.
Well?
LS rod, although its not a direct replacement. other than that they are all the same
Formally D_Tuned
97 civic HX
yeah u can run 10-12 psi on a stock motor depending on snail size and how well the tune is
i was at 10 and now building for 20+ with a bigger turbo and nitrous
spec V /Mach1
I know i'm gonna want more but right now money is tight, so just doing a low low budget build for now. I'm already thinking of 12psi and haven't even started lol.
unless you plan on tearing down and replacing the internals with after market rods AND pistons.. you'll be fine with stockers. Nobody should pull there rotating assembly apart for just rods.
The Great Weldini
91 civic
these:
there are for a 4000hp 2.2l sohc 1.6.
Well?
good lord that make that pauter look like shit lol
PSI don't break things. it's HP. So a small turbo with 10psi might be totally fine on stock rods... But 10psi on say a .60trim will break things.
1 - 20 of 51 Posts
