1 - 20 of 142 Posts
1989 ed9 166k (irrc) motor was built 8k ago (iirc)
Engine-
K&N Tapered cold air intake (baseline)
All In Fab tapered-Vstack intake (final dyno run)
z6 throttle body unported
z6 intake manifold unported
Port matched TB, Intake, Head and Header
Mild ported head
Bored .20 over
11.1 JE pistons
Fully balanced
Arp Head studs
Arp Rod bolts on factory rods
Manley 1mm oversized/undercut swirl polished valves new valve guides/seals
10,000-rpm valve springs
Web Cam grind #148e/273 retarded two degrees (baseline)
Delta 282 grind retarded two degrees (final dyno run)
AEM adjustable cam gear
Single belt crank pulley
RC engineering balanced stock Injectors (baseline)
Injector Nation 600cc injectors (from member highprofile) (final dyno run)
Fuel pressure gauge on filter under hood
Adjustable Fuel pressure regulator
8mm Magnecore plug Wires
ECU socketed and chipped for turbo edit reprogramming with launch rev limiter. Running stock map. (baseline)
P28 ecu with hondata s300 (final dyno run)
Ebay 4 2 1 wrapped header
No Catalytic converter
2.5” exhaust
poly motor mount on cross member, new oem at firewall
Trans-
ACT 3 puck sprung clutch
8lb flywheel
Short shifter with poly bushings
Suspension-
Ground Control Coilovers
Tokico blue shocks
Ground Control shock travel extenders
Misc. Poly bushings
Front Strut Bar
Spoon knock offs
Brakes-
Integra 4 wheel disc brakes
Prelude 15/16 master cylinder
Racing pads & stock rotors
Steel Braided brake lines
Speed bleeders
91 CRX brake lights
Interior-
Auto Meter Oil pressure gauge
Auto Meter Water temp gauge
Auto Meter A/F ratio gauge (not wideband)
Grant Steering wheel
138whp baseline was with items that are listed as baseline above
150whp baseline was with items that are listed as final dyno run above.
I tuned the car two weekends ago. Car was tuned on 93 octane. Engine was breaking up very badly due to faulty obd0 to obd1 jumpers, we only manged a handful of clean passes on the dyno that we could dial the car in. It was breaking up randomly at all rpms, it also would not allow the engine to rev past 7k rpm. RyWire jumpers came in last week and cleared up the issue instantly, I will redial the car in very soon. Im sure there is power to be gained below 7k and well be able to tune past 7k.
Side note, my goal was 154 whp, reason for this i had a 1993 nissan nx2000 more then 10 years ago that i built and loved. its first set up was a all motor 10:1 redtop sr20de 2 liter twin cam motor with jwt s4 cams, full underdrive pullies, intake, header, exhaust, injectors and a tune. it was a blast. (i would go on to build that car for close to 10 years, multiple motors, turbo 400whp, all motor 250whp etc etc) oddly enough my friend who tuned the crx, ended up buying the same dyno i was on over 10 years ago, so its great for comparison !
Next I will be focusing in on the transmission, not sure wether ill be bulding the current one or trying to grab a dohc one. In either case a final drive and a lsd will be installed.
After i will focus on a better header and intake manifold.
You can view more pics, dyno videos on my instagram rustylcog is my handle.
Stratton.
D-series Janitor
Front Engine Dragste
Saw the pictures on IG . . . so clean. Looks fantastic.
Surprised these cams are making peak HP so low . . . I know you've got the distributor/wiring thing but it looks like the HP curve has already started to level off around ~6600.
Also interesting the 282 is smoking the webcam everywhere. Would have guess it would have been the otherway around considering the price. :)
id have to look at my buddys dyno whos running a 272 cam and compare. we both have our cams retarded two degrees, maybe i should try one one more degree. but yes, i was guessing it would be in the higher rpms.
but like i said, it was breaking up badly. only way to know for sure is when i go back to the dyno and dial it in one last time.
driving the car it feels great past 6500 all the way up to the factory 7200rpm.
does anyone have any dyno sheets with any all motor a6s peaking much higher ? curious what set up and what cam.
Regardless, the delta 282 cam was a great improvement.
stratton.
^ a couple.
just sold my g35x so i may jump on this trans ive had in mind. s30 with a dohc gear stack, ats 4.7 final and ill toss in a lsd.
should set her off just right.
any opinions on the dyno, parts, future upgrades ?
stratton.
beautiful build!
Where did you get your single pulley crank? Or did you mill down a stocker?
i dont even remember. honda use to sell it. you can still find them on like ebay or junkyards.
im so ocd, i actually powdercoated it factory silver when i did the valve cover lol.
stratton.
Went to the dyno to re-dial in the upper rpm now that the RyWire jumpers cleared up all my issues.
With the cam gear retarded 6 degrees we ended up with 159whp 126wtq @7k rpm.
Beat my goal by 6whp so I couldnt be more happy. I have plenty of things in mind for more power, but im currently eyeing up a built tranny that will be perfect for the crx.
Stratton.
yes, that is the plan ;) . i believe with the the right parts and fuel i can make some significant gains. but this will all happen after the tranny.
stratton.
Thanks guys!
Ive secured a si trans, zc dohc gear stack, ats 4.7 final and i will have a m-factory lsd installed. i will be having aquafina go over the trans, replace anything that needs to and he also media blasts the case.
i will install it as soon as i recieve it from aqua.
then i think i can take some time and just enjoy the car (as i have been) this winter i will add a custom header and a custom intake manifold or possibly itbs. it never stops lol.
stratton.
Holy guacamole! I did not think this kind of power could be made from an NA D16.
Love the all-function setup you have going on, no flash or fluff on this thing.
Not sure whether to laugh or cry that your D16 makes more WTQ than my B18.
Keep up the good work.
keep in mind this is on a d16z6 intake setup.
there is more power to find!!!
I would not be surprised if you soon achieved 180whp
Discussion Starter #19
The new found hp and tq really makes the chassis and suspension shine. Looking foward to seeing how the built trans steps things up a notch.
ive always been function over form.
I plan on seeing this old girl through, the gears in my mind are always turning (couldnt stop them if I tried).
As always though, reliability and driveability are most important, but there are obvious areas were more power can be extracted.
ty guys.
stratton.
simple edelbrock performerX install and retune will net you nearly 10whp over that suffocating d16z6
1 - 20 of 142 Posts
