1 - 20 of 76 Posts
* updated thanks for the warm welcome guys, have some specific questions at the end of the thread*
Hey guys, I've been a long time lurker. just a short history, I was alway into nissans, primarily b13's, se-r's or nx2000's. Ive owned many and built a few. My main one was a nx2000 that went threw many motors, high comp nitrous, high comp turbo, low comp turbo, even bigger turbo and ending with a fully built sr20ve that was sleeved, stroked, ported etc etc 2.4 with 15:1 compression etc etc. i sold that about 4 or so years ago, and bought a 2002 jeep wrangler, wich ive modded to hell and wheel often. My good friend was always into crxs and ef si's. Ive always really enjoyed his cars, now this is going back about 10 years ago. Somewhere in that mix ive all the nissans and other daily drivers i had a mint, 1991 ef sedan, dpfi and auto.
ive always wanted a crx, always enjoyed sohc's for the simplicity, and how fun they were to mod. this is now my second honda, my first crx.
Engine-
K&N Tapered cold air intake
Bored throttle body
Port matched TB, Intake, Head and Header
Mild ported head
Bored .20 over
11.1 JE pistons
Fully balanced
Arp Head studs
Arp Rod bolts
Manley 1mm oversized/undercut swirl polished valves with new valve guides and seals
10,000-rpm valve springs
Web Cam grind #148e/273
AEM adjustable cam gear
Single belt crank pulley (sourced from New Zealand)
RC engineering balanced stock Injectors
Fuel pressure gauge on filter under hood
Adjustable Fuel pressure regulator
8mm Magnecore plug Wires
ECU socketed and chipped for turbo edit reprogramming with launch rev limiter. Running stock map. (I have 2 launch chips. 3,500 and 4,000 rpm)
Generic wrapped header
No Catalytic converter
2.5” exhaust
Poly motor mount on crossmember. New stock mount on firewall. Happy medium for vibration
Trans-
ACT 3 puck sprung clutch
8lb flywheel
Short shifter with poly bushings
Suspension-
Ground Control Coilovers
Tokico blue shocks
Ground Control shock travel extenders
Misc. Poly bushings
Front Strut Bar
New Drag rims and basically new tires 195/50/15
Brakes-
Integra 4 wheel disc brakes
Prelude 15/16 master cylinder
Racing pads & stock rotors
Steel Braided brake lines
Speed bleeders
91 CRX brake lights
Interior-
Auto Meter Oil pressure gauge
Auto Meter Water temp gauge
Auto Meter A/F ratio gauge (not wideband)
Old school Alpine radio
Denon Amp
10’ sub in wedge box
Kenwood EQ mounted in ashtray slot
Grant Steering wheel
Clearly i dont have to explain the appeal to you guys, just the nostalgic feeling you get when driving it, the feedback threw the wheel, the subtle communication the car gives me when im driving makes me feel how i did when i first got into imports over 15 years ago.
stratton.
thanks guys.
no real plans for her. maybe some azenis tires or even better, some dunlop direzza star specs, they were amazing on my last car.
maybe a rear strut brace if it doesnt mean cutting up of any rear plastics.
id love to get into some autocrossing and maybe finally hit a road course after all these years of building cars and street racing lol.
stratton.
Love the Civic
That is a beautiful rex, more pics....
90 CRX Si
Get the new Z2 Star Specs, way better than the Azenis.
That said, I like the car. I'm saving parts for a resto mod on my 89 black Si as well, I'll keep up with yours for inspiration lol
Looking into getting a harness kit from rywire, doing a s300 ecu.
Id love to get a baseline and see what a good tune can pull out of her.
No one local i can find messes with turboedit anymore :/.
I think she can do 150ish no problem.
Thoughts?
Stratton.
ej8
Beautiful car!!!
How to get (Single belt crank pulley (sourced from New Zealand)) ?
Because I don't have AC and PC maybe it will work for me too
Asshole
You can buy them new for any civic that didn't come with a/c and power steering or get one from the junkyard. There is no need to get one from the other side of the world.
there you go !
just what i was told from the person i bought it from. thank you for the clarification.
stratton.
Discussion Starter #16 (Edited)
hey guys. im getting around to getting some parts together to get her tuned. i have some specific questions regarding tunning.
the parts list is clearly above so feel free to use that as reference.
1st question.
going to get the rywire obd0 to obd1 kit, harness jumper and it comes with whatever other plugs/wires i need to convert. is this the right one ?
Rywire.com - OBD0 to OBD1 ECU Conversion Harness
*We can also supply you with a OBD0 to OBD1 (or OBD2) Distributor Adapter*
^this is so i can run a obd1 p28 with a s300, and use my factory obd0 distributor with an adapter. is this correct ?
also it mentions i need to run a 4 wire 02 sensor, anyone that should be recommended ? also were can i find the flange that needs to be welded in ? i could also ask rywire these question, but figured id run it by the pros first.
2nd question
it seems difficult to find cut and dry cam info on. i have a Web Cam grind #148e/273 with an adjustable cam gear. is there anyone who had tested what degree advanced or retarded that provides the most power, or even a starting point to help eliminate guess work on the dyno. i also plan on putting a 8100rpm rev limiter on her threw hondata. i have to look but if i recall it was retarted a degree or two upon installation for top end.
any idea on what kind of whp i could be looking at ? im going to have it tuned by a very well respected tuner, so i have no doubts in his ability. just curious at what i could be looking at. im going to have him tune it on 93, aggressive but safe tune.
last question, it has the si L3 open diff trans. i want to add lsd. any go to lsd's that you guys trust and have been proven reliable ? also is it worth it to add a mfactory final drive ? if its worth it ill do all the work on the trans at what time. if so what final ? its a street car, just a weekend cruiser but if a nice final will add some more acceleration im all for it.
im also going to add a innovative traction bar to eliminate wheel hop.
with all that being said, ill see where im at with all that has been mentioned above. id possibly be intrested in tunning on e85, either going to a fully built z6 head thats milled for more compression and add that 59300 cam i see mentioned so often. or pulling the a6 head, fully porting it and adding a bigger cam and milling it agian for higher compression. of coarse bigger injectors and fuel pump.
thanks in advance for any replys.
stratton.
Discussion Starter #18
theacidbeaver's up in that area isn't he? He's about the only one I know that does TurboEdit or TunerExpress.
maybe, i dont know him or know of him.
im just going to with a p28 with hondata.
unless he is very close and has his own shop/dyno.
stratton.
\/Your Mom Was Here\/
Vibe GT
Contact The_Acid_Beaver and see if he is willing to help, if he see's you are somewhat educated on motors and such he will help you out. But you must email him and DO NOT PM him.
Click here and go to "contact info" and click "Send a message via email to xxx"
http://www.d-series.org/forums/members/the_acid_beaver-14805.html
1 - 20 of 76 Posts
