Hello,
I am currently preparing a d16y3 (read d16a6 with z6 head gasket) for an engine swap. I bought a delta 272 cam as an upgrade as they're relatively cheap and meant to be pretty good.
Now i've got an adjustable cam gear and went about degreeing it in today using the following cam card(as most know delta don't seem to supply them with their cams which is odd);
Now that cam card states that at .050 of lift(opening and intake) the cam should sit at 4.5BTDC of which it does now after some minor fettling, it also closes at the correct crank angle 32 degrees ABDC.
How ever i proceeded to measure the lift at .050 intervals like the cam card to check the specs of the cam and after 0.050 it all went a bit tits up. My findings went as follows;
intake cam opening(BTDC);
0.100 - -12.5
0.150 - -25.5
0.200 - -38
Intake cam closing(ABDC);
0.100 - +16.5
0.150 - +5
0.200 - -6
They are way off what the cam card says it should be as the lift gets higher the gap gets bigger. Also the lift measured from the top of the retainer was measured at 0.361" when it should be 0.394" according to the cam card.
The exhaust was even worse, it didn't even match up a 0.050" which i can't adjust as according to the intake side its zeroed.
Exhaust opening (BBDC);
0.040" - +46.5
0.050" - +36
0.100" - +23
0.150" - +12
0.200" - +1
Exhaust closing(ATDC) sorry i only have from 0.006"-0.050" of lift.
0.006" - +2
0.015" - +0.5
0.020" - -7
0.040" - -14
0.050" - -17
Now the exhaust closing isn't too bad(in comparison to opening) with specs being only approximately 3 degrees out. But opening at .050" is almost 14 degrees out from what the cam card says it should be.
Also i measured the lift to be .380 - 0.010" more than stated on the cam card.
This was my first time degreeing a cam but i have done lots of research towards the subject. TDC was found using a piston stop and valve lash was set to zero.
Now can anyone explain why my results are so far from what the cam card says they should be?
Bad regrind?, maybe im doing something wrong? The dti was put on top of the retainer ensuring it was at the same(or as close to) the angle of the valve.
Any info would be great,
Lee
0.100 - -12.5
0.150 - -25.5
0.200 - -38
0.100 - +16.5
0.150 - +5
0.200 - -6
0.040" - +46.5
0.050" - +36
0.100" - +23
0.150" - +12
0.200" - +1
0.006" - +2
0.015" - +0.5
0.020" - -7
0.040" - -14
0.050" - -17
Lee
