1 - 16 of 16 Posts
same
What is the proper position in which to store the crank? Is it ok to have it laying flat for extended periods of time or should I store it in a vertical position? I don't want it to warp from storage. Or am I being paranoid :3dtard:
same
Well shit! I have it horizontal going to repack it tomorrow it's been like this for about 6 months. Might still be ok though.
same
That crank looks like sex!
a car
yeah should be ok. as long as it doesnt have heavy items or constant heat on it then you should be fine. but yes store it vertically in a storage bag from an auto parts store. they are usually free. also you may want to put a thin coat of oil all over the crank to void off rust. has worked for years for me
same
It's been stored in it's own box without anything in it but I will rewrap it and put it in a vertical box until my new build begins.
I normally spray it with WD40 and put it in a trash bag, then leave it standing as in the picture above.
proper storage = IN A MOTOR!
Hang it from a noose or sit it in a corner upright, one thing Honda stock cranks have never been an issue.
1992 Civic Si
From a noose? rofl
I wouldn't trust a good crank to a rope, unless I had a beanbag chair to catch it if it fell.
I thought about that. What about laying the crank in a girdle? Think that would be a good idea?
1988 Honda CRX
I have heard this argument over and over.
I have used cranks that where left layin on a shelf for years. I never found one that was bent as a result.
I have seen cranks stood on their end that have been knocked and fell over and bent or got nicked or dented.
Every new crank I ever bought came laying flat in a box.
The vast majority of cranks in running engines are stored horizontally, except some outboard boat engines.
Just think about the effect of gravity on a crank vs impacts from the cylinder firing
Formerly 95RedVXCivic
95 VX, 88 S/C MR2
it doesn't matter which way you store it as long as it is safe from the elements, and from things falling on it or it falling off.
excellent point :bigok: listen to this man... he speaks from logic :yes:
Hang it from a noose...
It's statements such as this that should warn people don't piss this man off... lmfao
same
It's in a box in the shed and that's insulated so its in less extreme elements than the motor. I like the girdle idea.
1988 Honda CRX
If a thick steel crank can bend from gravity, what keeps a thinner aluminium girdle from bending under the same load.
I agree if the crank and girdle are in a block, it is the safest place to store it.
1 - 16 of 16 Posts
