1 - 20 of 21 Posts
formerly allnaturalrex
1989 honda crx si
depending on the tune i have seen and experienced around 200hp+ max i have seen 225hp. depending on the condition of the engine as well.
but yea you need to search buddy before you post
See above...
My local friend and member here is boosting near 13 lbs and netting 300whp on a completely stock Z6! not even headstuds!
im sure it could be done but.... its not reliable
its not a matter of if, but a matter of when it WILL blow up @ 300hp
honda/firebird form.
i ran 18psi on a stock z6 with head stds with a 57 trim for about 6 months then a bearing let loose
thats about 320-340hp give or take... were the rods bent some when you took it apart?
1 - 20 of 21 Posts
