1 - 12 of 12 Posts
2005 Civic Si
question #1
so I built a d15b7 (oem rebuild with all new parts) and it was decked .005, I also have a milled d16z6 head with all new valvetrain (down to the guides and seals) im looking into a cam (bisimoto level 3 to be exact) what will I need to run this cam tuning wise? will I be able to wing it with the oem p28 ecu in her del sol? (im going to assume not) also a skunk 2 intake manifold and bisimoto header are in the future. (currently have a ported z6 intake manifold and DC 4-2-1 header)
question #2
to break in that bottom end I planned to run he stock z6 head on it for a few weeks or so while I finish building the new head, since everything is esentially stock just set it up like a regular mini-me and go with it? or again any special tuning needed?
1993 Cobra
just run it like a usual mini-me. Obviously you wont be able to use a stock ecu to run that big cam with your upgraded breathing capabilities. But the stock p28 will be fine to break the motor in while you build the other head. :td:
Reactions: EP3Moschini
1993 Cobra
probably crome, xenocron socket/chip kit, freelog and a friend. lol Look for a motor setup close to yours and make a basemap.
2005 Civic Si
I was thinking that I could find a used p28 and get it socketed and burn chips (ive done it once or twice for base maps) ive never actually tuned anything and im only familliar with chome
1990 civic 4 door LX
With the price of a p28 I would grab the cheapest obd-1 chippable ecu and then burn a stock p28 map you want to use. I don't think a level 3 cam will be to your liking... a level 2 would probably be better... level 3 is a big cam... the powerband will not be what you would be in for daily driving. The bottom end is going to want to spin higher because of the cam. It won't "die out" and your compression will nowhere be enough for that cam without messing with the cam timing (advancing cam).
If you will be tuning it a vac. Gauge would help. You know, so you know where to touch on the map. It does go off of a vac./mbar reading...
Ps- goodluck. Mini-me is a good way to make quick power and quick compression.. it will be fun. Just don't over-do the cam or you will regret it. It is your complete powerband change (in your case)
The bisi header is dope and I am a big supporter but I would say build your own or stick to the dc you have and spend the money somewhere else... it is a luxury and if you want it get it but homemade off his design would be definately cheap and I made a few and they all made bomb power... and I still need one to run on my car!
My 91 Crx Hf
97 Civic Coupe
pic's or proof that they made good gains?
OP: you should be able to run the stock p28 for the break, should be perfectly fine I would keep it under around 4k though. If you just get a chipping kit I am pretty sure someone on here can make you a basemap in no time, if not e-mail phearable.net they'll probably hook you up with a great basemap pretty cheap
I will as soon as my laptop is back online. I've been using my phone for the past month and its hell..
The bisi design is awesome. I changed the way the runners go. To make it look different. The compression and velocity made from the header in the upper most area was definately decreased. Made similar charts for power bands on similar built motors but the header is definately a fine science. The math skill required alone is significant. anyone try an an-r header?
Ill take pics of a b series one I will be building here shortly also.
Wow.. phearable? Are you at the same sea level as him? That can drastically change a tune. And a basemap wasn't even tested on your setup before you receive it. Your better off reading and making and honest effort to tune yourself.. don't be a know it all just read and learn and masybe have a tuner help you.. it will be inexpensive if you know what you are doing and reliable. Which is better than a non aggressive enough or worse to aggressive basemap. The latter I doubt will happen.. you will just be under powered and possibly kill your gas mileage. But now if you do it with a wideband you can monitor and if you tune yourself you can make changes as needed..
Obviously its a bad idea to read and tune so try tuning a little on your car before hand. Learn how to use the program and you will be set. When I was 16 I tuned my own accord and after learning on it I tuned my own turbo civic. The knowledge gained alone ion my own things has helped and helped me help others... I always refer people to get tuned if its anything more than bpu's. I/h/e. Most anything more shouldn't be run on a stock ecu...
A tune would be the best but you may be able to wing it on the stock p28 If you get a wide band o2 sensor you will be able to tell more.
2005 Civic Si
:yes: for now im just concerned about breaking int he bottom end with here oem z6 head, then once the built head is ready im going to worry about tuning it lol
1 - 12 of 12 Posts
