1 - 6 of 6 Posts
i seem to have considered almost everythign in my build up but forgot these ! . also the ignition . how many hp is it rated to ? how much can the stock driveshafts hold b4 breaking
O
I'm running stockers and they work fine fo rme. and i'm doing clsoe to 400 hp. But I also know how to drive the car. if you properly pre-load the axels before launching then you should be ok. if you don;t then you'll snap axels a lot.
O
when your on the line, you hold the -ebrake handle so the car won;t move and slowly let the clutch out and when you feel it starting to grab and pulling the car then you stop and that's putting a load onthe axels so it's not jolting them forward. (you are still reving to what ever launching rpms your running)
stock axles, 200 hp, 7800 rpm dumps on slicks, no axle issues.......
O
^ that's what I'm saying.
i have 400 hp, 6500 rpm preload with 2step going and making about 10-12 lbs of boost at the line on drag radials and no problems.
1 - 6 of 6 Posts
