Hello there fellas. This is my first post on d-series forums and quite excited for everybody's input in helping me boost my d16y8 on stock internals.
So to start off, I have a 95 honda civic ex with a d16y8 swap. It has been converted to obd1 and I still have the p28 ECU. Not sure if it is chipped or not.
I have been doing research for many months now and building a budget for my build. At first my plans were to fully build my engine, eagle rods wiseco pistons, crower stage 2 cam, fully built head, stage 4 clutch, so on and so forth. (keep in mind I had plans of capping my build at 8k.)
However I have changed my mind due to my budget drastically dropping. I would like to keep my budget at 3k or as close to that as possible with still having a reliable boosted engine.
I have been looking at the go-autoworks street kit. As I've noticed this will definitely meet my needs of 150-325 hp.
MY GOAL is only wanting to be around 200 hp, 220 max and 190 min. I know that d series oil pumps (other than z6's), will need to be ported/shimmed so that way I will not spin a bearing. I am only wanting to boost on 9lbs max, lower if 9lbs is unreliable. THIS WILL BE A DD CAR.
MODS I PLAN ON DOING :
ARP head studs/bolts
Cometic Head Gasket
Oil pump port/shim
QUESTIONS I HAVE SO FAR (will update) :
Is the only thing I need to do before removing the ecu to check for a chip is disconnecting the battery terminals? (Dad told me I could fry my ECU by removing it, however he also claimed that if the timing belt snapped it could easily be replaced in which I had a good mechanic friend of mine explain to him that honda's are interference engines)
Can my d16y8 engine handle 9 PSI with only a chipped p28 ecu, bigger injectors, 255 walbro fuel pump, oil pump port/shimmed? I'm also aware that before boosting on stock internals I need a compression/leak down test, which I am looking for someone near me to do this. (Located between Lexington and Ashland, Kentucky)
What is the difference in port/shimming an oil pump? Is a port/shim a combination OR do you do one or the other?
If this build is accurate so far, capping at 220hp, will stock motor mounts handle this or should I upgrade to Innovative motor mounts?
What other cheap but high quality parts will help insure the life of my engine? Acl race bearings?
BUILD STATUS: Still in research
Cometic Head Gasket
Oil pump port/shim
