1 - 10 of 10 Posts
So tune? But how.. its so hard.
I thought I read you were supposed to leave it stock and if you tuned, you had to retard your timing?
Does anybody think I need to get better injectors to if I run nos?
D
You won't need injectors, but you will need to retard timing. As to how much would depend on a tune. I'm sure there are some folks on this site that could steer you in the proper direction so you wouldn't need to say go to a dyno. I'm more or less try to show you the cautious side.
yeah my friend HAD a 75 shot zex kit.....had until he blew 2 y8's and a jdm d15b vtec...then after all those shananagans he sold it to me, which im getting the 35 shot jet
Aynatix said:
Stock d16y8 + Nitrous = Bad?
bone stock y8 with no timing retard can handle a 55 shot all day long. to run the 75 shot i recommend a higher volume fuel pump and adj. fpr that's set to 50psi and then 4 degrees timing retard. anymore and you should have a wet kit or bigger injectors.
1 - 10 of 10 Posts
