1 - 3 of 3 Posts
I have an OBD1 jdm d15b vtec engine and I was looking to boost it in the future. I was planning on upgrading to golden eagle or scat h beam rods for strength for boost later, but I didn't really want to run vitara pistons and lose the stock 9.4:1 CR as it will be driven in N/a Form until the turbo kit is paid for.
Is there a piston on the market that will keep the same or should I try to find stock Pistons (if available, not sure)? I don't want to start the build until I have a clear plan of attack.
Get the d16 or custom length rods and some vitaras.. if it sticks out the block... about 0.5mm, just skim it off at a machine shop...
Did mine the same way used d16 fj h-beams.. not much if any difference from stock... boosted now.. 280 whp at 17 psi... HX35 turbo..
1 - 3 of 3 Posts
