1 - 20 of 30 Posts
oem part number
53323-SM4-013
car source word of mouth
96-00 civic manual steering
96-97 del sol with manual rack (rare), possibly 93-95 also
car source from honda, not always guaranteed as they chunk all models into one year at a time
93-97 del sol
92-00 civic
86-93 accord
key notes, big spline for column, small spline for rack
drop a shipping quote to 54601 in a small flatrate so it gets here fast
thanks guys
going to be using an eg rack to my ek power column
manual as in manual steering, not tranny :bigok:
EG8
Hmmm, the myth is you can swap an Integra power steering gear in the EK to gain some L to L.
The hard part is IDR if you swap to an Integra U joint or not though...
But if a power EG is the same, I have a spare one for you.
if you have the vin, pop it into myhondapartsstore website
I am going to manual steering. I want to remove power steering and use my eg subframe I got from will
lol, if I didn't already tape the hell out of this box, and the part fits, I coulda thrown it in the box and saved yall the headache lol
edited my goof. was going to say, I still have my steering column with the joint in the shell.......shell has been taken away already. derrr
ej8
Yea he has ps in his 98 and we order a 98 banual rack.
I still think the eg joint was from a power steering car tho.
that has power steering. rack snout is different sadly
EDIT fuck!!!
ej8
Im confused
yea me too. No idead what the hell he is trying to do.
I can say this tho.
I swap out my friends 98 ps rack for a manual rack.
ON the PS setup. The ps rack is bigger then the steering wheel gear.
ON the manual rack both are the same size.
we comb the junk yard and all the 6th gen civic were PS.
found a 5th gen civic (eg) i believe, the rack U joint from it work. Both ends where the same size.
hes using a 92-95 subframe and manual steering rack with a 96-00 steering column. the column is thicker/different tooth count than the steering rack.
where Im confused is, does the 92-95 4 door work? does the 92-95 power u-joint work?
EG8
So if Xile is right, the EK uses the Integra sized steering gear. I think the EG power was the same on both sides, but I didn't look too hard either.
But your part # matched on the power rack... lol...
Discussion Starter #16
will read.
thanks for input guys.
I had no idea eg splines were similar pairs
OK, read that.
Im not using a power rack and looping to go manual steering.
I think that would be an awesome route to go if I stayed power though. I had no idea the teggy pinion fit EK power racks
I was thinking more along the lines of expanding your search options.
Discussion Starter #19
I think I will add "swapping manual rack into integra"
that might have a bit more search options
1 - 20 of 30 Posts
