1 - 3 of 3 Posts
i read that the std hatch has different spindles and axles ... if i swap a z6 or d15b will i have to get different axles too ? thanks alot
Lifetime Awesome Member
'89 CRX HF
no you do not have to get different axles. the outer splines are the only thing that is different. the inners are the same, I.E. all model trannies will match all model axles. you can use an SI tranny or whatever and as long as you still have the STD hubs, you can use STD axles
1 - 3 of 3 Posts
