1 - 10 of 10 Posts
M
okay i fed 12v directly to the motor and all i hear is the rotor spinning, it's not actually cranking the engine....anyone know what this could be?!!!
M
ok well i think the starter is totally screwed - i feed 12v to it and i know i've grounded the other end but nothing happens at all?
are these easy to rebuild?
what has actually broken here?
Hondaphile
see above
DON'T use a hammer, the magnets in the starter are ceramic and will shatter occasionally (I say this mainly due to the fact that half the time people are told to tap on the starter solenoid they bang on the starter in general....) use a screwdriver handle....if it doesn't free it up, you'll probably need to replace the solenoid or the starter....if it does it'll work, and you may have to do it again sometime....<shrug>
M
it wont spin at all when i feed it 12v
would a hammer help at all?
M
i thought u were spose to hit it if it just spins but doesn't turn the flywheel?
mine doesn't spin at all?
i'll try to hit it
M
the starter motor is from a carb transmissin
the flywheel is from a d15b vtec
would this matter?
i heard that it might not be compatible
can someone confirm this?
1 - 10 of 10 Posts
